Inleiding
In this guide you will learn how to replace your Asus Vivobook X540SA-BPD0602V's Hard Drive. Replacing your laptop's Hard Drive is a necessary step in upgrading the devices memory.
Wat je nodig hebt
Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
Very carefully, remove the batteries with the blue plastic iFixit opening tool. Focus removing the battery near the highlighted area.
The Disk Drive is located within the upper right hand corner of the laptop.
The Hard Drive is located in the bottom right hand corner. It should be the device covered in black foam.
Één andere persoon heeft deze handleiding voltooid.
