Ga door naar hoofdinhoud
Asus VivoBook X540N HDD to SSD Replacement
Wat je nodig hebt
  1. Asus VivoBook X540N HDD to SSD Replacement, Opening the laptop: stap 1, afbeelding 1 van 3 Asus VivoBook X540N HDD to SSD Replacement, Opening the laptop: stap 1, afbeelding 2 van 3 Asus VivoBook X540N HDD to SSD Replacement, Opening the laptop: stap 1, afbeelding 3 van 3
    • First of all you need to remove the 10 screws holding the laptop together.
    • Then use plastic or metal spudger to separate the bottom cover from the keyboard and touchpad assembly.
    • Once you open it, carefully unplug the keyboard and touchpad connectors. Be very careful not to damage them!
  2. Asus VivoBook X540N HDD to SSD Replacement: stap 2, afbeelding 1 van 3 Asus VivoBook X540N HDD to SSD Replacement: stap 2, afbeelding 2 van 3 Asus VivoBook X540N HDD to SSD Replacement: stap 2, afbeelding 3 van 3
    • Once you open it, it should look like this.
    • You need to unscrew the only screw (marked in red) to be able to remove the HDD.
    • When you do that, just unscrew the 4 screws attatching the HDD to the bracket and replace it with the new one.
Conclusie
Simeon Brankov
8.432 Reputatie
62 handleidingen geschreven
4Gids Commentaar
Pls. Do more tutorial like this. It is very helpful to lack of knowledge person ?..
Would you mind to complete your tutorial regarding disassemble / assemble of this laptop model ?
For example : processor replacement
Heat sink replacement LCD replacement
Battery replacement
Hinges replacement
Thanks In Advance !
More Power !
Gilbert Gutierrez - Antwoord
Hello,
Im glad that you found the information useful. Unfortunately this laptop is no longer with me, if I come across the same model again, Ill be sure to make a more advanced tutorial.
Thank you and have a nice day :)
Simeon Brankov -
Sorry, I tried to replace it and the bios does not recognize it.
David - Antwoord
Hello,
This can indicate a problem with the SSD itself and/or the drivers on your laptop. Have you tried to load the drivers manually during Windows installation?
Simeon Brankov -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 67
Altijd: 2,789
