Inleiding
You may need to replace the battery if it does not hold a charge or the laptop does not turn on. Be aware that this battery is a Lithium-Polymer battery and can explode if punctured.
Wat je nodig hebt
Flip the device such that the labels are on top.
Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
Use the same screwdriver to remove the four 5mm screws in the front.
Use the same screwdriver to remove the single 9mm screw in the center.
Één andere persoon heeft deze handleiding voltooid.
