Ga door naar hoofdinhoud
Asus VivoBook S200E-RHI3T73 Touchpad Replacement
Wat je nodig hebt
  1. Asus VivoBook S200E-RHI3T73 Touchpad Replacement, Touchpad: stap 1, afbeelding 1 van 2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement, Touchpad: stap 1, afbeelding 2 van 2
    • In order to remove the back lid, you must lay the laptop down with the lid closed and remove the screws with a Phillips #0 screwdriver.
    • There are five 80mm screws.
    • There are four 50mm screws.
    • Pull the back lid off of the laptop using your fingers.
  2. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: stap 2, afbeelding 1 van 2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement: stap 2, afbeelding 2 van 2
    • There should be a total of twelve 50mm screws when removing the battery.
    • The battery does not have to be fully removed for this step, however the screws must be taken out and the battery lifted.
  3. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: stap 3, afbeelding 1 van 2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement: stap 3, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to remove the six screws attached to the silver panel.
    • Disconnect the LED ribbon wires using a spudger to lift the clamp.
  4. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: stap 4, afbeelding 1 van 2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement: stap 4, afbeelding 2 van 2
    • Using the Phillips #0 screwdriver, remove the four screws on the silver panel.
    • Using a spudger, gently lift the silver ground strips off of the touch pad.
    • Pull the touch pad up and towards the battery to remove it from the laptop.
Conclusie
Katherine Nasci
124 Reputatie
1 Handleiding geschreven
IUPUI, Team S9-G9, Wilson Spring 2019 Lid van IUPUI, Team S9-G9, Wilson Spring 2019
IUPUI-WILSON-S19S9G9
4 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 757
