Ga door naar hoofdinhoud
Asus VivoBook S200E-RHI3T73 Keyboard Replacement
Wat je nodig hebt
  1. Asus VivoBook S200E-RHI3T73 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the nine 50mm screws and lift the panel.
    • Be aware of sharp metal edges once the panel is removed.
  2. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to remove the twelve 50mm screws around the battery.
    • Gently remove the battery to avoid damage.
  3. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: stap 3, afbeelding 1 van 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: stap 3, afbeelding 2 van 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the Phillips #0 screwdriver to remove the five 5mm screws around the fan.
    • Use the precision tweezers to unplug the fan cords.
    • Be cautious of pulling the cords.
  4. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: stap 4, afbeelding 1 van 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: stap 4, afbeelding 2 van 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Use the Phillips#0 screwdriver to unscrew the 3.5mm screws from around the motherboard and the 6mm screws from around the PCB.
    • Double check for unloosened screws. Bending the boards can damage the hardware.
  5. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: stap 5, afbeelding 1 van 2 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Use the Phillips#0 screwdriver to remove the 50mm screws on the boarder of the metal panel.
    • Be cautious of sharp metal edges.
    • Carefully remove the panel. Without care it will bend and be difficult to reassemble.
  6. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Using the Phillips#0 screwdriver, remove the 50mm screws surrounding the keyboard.
    • Gently remove the keyboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 614
