Ga door naar hoofdinhoud
Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement
Wat je nodig hebt
  1. Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 2 Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
  2. Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: stap 2, afbeelding 1 van 2 Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Insert the flat edge of the opening tool in between the back casing to remove the back casing.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: stap 3, afbeelding 1 van 2 Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Using the JIS #0 Screwdriver, remove the five 3.0 mm screws that hold down the hard drive casing.
  4. Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: stap 4, afbeelding 1 van 3 Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: stap 4, afbeelding 2 van 3 Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Lift the hard drive up and remove the power supply cable connected to it.
    • Make sure to pull on the plastic head and not the actual wires to prevent tearing them.
  5. Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: stap 5, afbeelding 1 van 3 Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: stap 5, afbeelding 2 van 3 Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Carefully peel back and remove the plastic hard drive cover to reveal the two 3.0 mm screws on the hard drive casing.
    • Using a JIS #0 screwdriver, unscrew the two 3.0 mm screws on the side of the metal casing to remove the hard drive itself.
Conclusie
Deric Wright
636 Reputatie
3 handleidingen geschreven
USF Tampa, Team S5-G5, Eyestone Spring 2018 Lid van USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 11
Altijd: 864
