Ga door naar hoofdinhoud
Asus VivoBook Q200E-BSI3T08 Keyboard Replacement
Wat je nodig hebt
  1. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 3, afbeelding 1 van 2 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Motherboard: stap 4, afbeelding 1 van 1
    • Locate the motherboard under the cooling fan.
  5. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the two 5.9mm screws on the PCB board with a Phillips #0 screwdriver.
  6. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the PCB board from the motherboard.
  7. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Unscrew the four 5.9mm hard drive bracket screws with a Phillips #0 screwdriver.
  8. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 8, afbeelding 1 van 2 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Unscrew the four 5.9mm screws with a Phillips #0 screwdriver.
    • Next, carefully lift the LAN bracket out of the slot.
  9. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the five 5.9mm screws holding the motherboard in place with a Phillips #0 screwdriver.
    • Remove the five 3.5mm screws holding the motherboard with a Phillips #00 screwdriver.
  10. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 10, afbeelding 1 van 1
    • Carefully lift the motherboard up out of the slot.
  11. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 11, afbeelding 1 van 2 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 11, afbeelding 2 van 2
    • Locate and unplug the power bus from the motherboard.
    • The motherboard can now be replaced.
  12. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Battery: stap 12, afbeelding 1 van 1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  13. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 13, afbeelding 1 van 3 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 13, afbeelding 2 van 3 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 13, afbeelding 3 van 3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  14. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 14, afbeelding 1 van 2 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 14, afbeelding 2 van 2
    • Now just lift the battery out of place.
  15. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Trackpad: stap 15, afbeelding 1 van 1
    • Disconnect the small blue TP(trackpad) labeled data bus.
  16. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 16, afbeelding 1 van 1
    • Identify the ten 2.94mm screws on the metal bracket.
  17. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 17, afbeelding 1 van 1
    • Unscrew the ten 2.94mm screws with the Philips #00 Head.
  18. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 18, afbeelding 1 van 1
    • Remove all of the metallic tape holding the metal bracket to the components surrounding it.
  19. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 19, afbeelding 1 van 1
    • Lift the metal bracket away from the laptop.
  20. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 20, afbeelding 1 van 1
    • Unscrew the four 3.5mm screws with Phillips #00 Head.
    • This black plastic panel holds the trackpad in place.
  21. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 21, afbeelding 1 van 1
    • Lift the trackpad up from the laptop and slide it out of the housing.
  22. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Cooling Fan: stap 22, afbeelding 1 van 1
    • Unscrew the five 4.9mm screws holding the cooling fan in place using a Phillips #0 screwdriver.
  23. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 23, afbeelding 1 van 1
    • Unplug the power bus for the fan.
  24. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 24, afbeelding 1 van 1
    • Lift up and remove the cooling fan from the slot.
  25. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Keyboard: stap 25, afbeelding 1 van 2 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Keyboard: stap 25, afbeelding 2 van 2
    • Next, unscrew the two 4.9mm hinge screws with a Phillips #00 screwdriver.
  26. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 26, afbeelding 1 van 2 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 26, afbeelding 2 van 2
    • Remove the ten 4.9mm screws holding the metal keyboard panel in place, using a Phillips #00 screwdriver.
    • Carefully lift the metal keyboard panel out of the slot.
  27. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 27, afbeelding 1 van 1
    • Pull the display hinges back in order to remove the metal keyboard panel.
  28. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 28, afbeelding 1 van 1
    • Carefully pry and loosen the keyboard from the slot.
  29. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 29, afbeelding 1 van 2 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: stap 29, afbeelding 2 van 2
    • Carefully lift the keyboard out of the slot.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mitchell Jackson
742 Reputatie
7 handleidingen geschreven
IUPUI, Team S4-G4, Wilson Summer 2017 Lid van IUPUI, Team S4-G4, Wilson Summer 2017
IUPUI-WILSON-SU17S4G4
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 2,239
