Ga door naar hoofdinhoud
Asus VivoBook Q200E-BSI3T08 Battery Replacement
Wat je nodig hebt
  1. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Battery Replacement: stap 3, afbeelding 1 van 2 Asus VivoBook Q200E-BSI3T08 Battery Replacement: stap 3, afbeelding 2 van 2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Battery Replacement: stap 5, afbeelding 1 van 3 Asus VivoBook Q200E-BSI3T08 Battery Replacement: stap 5, afbeelding 2 van 3 Asus VivoBook Q200E-BSI3T08 Battery Replacement: stap 5, afbeelding 3 van 3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Battery Replacement: stap 6, afbeelding 1 van 2 Asus VivoBook Q200E-BSI3T08 Battery Replacement: stap 6, afbeelding 2 van 2
    • Now just lift the battery out of place.
Conclusie
14 andere personen hebben deze handleiding voltooid.
Maxim
462 Reputatie
1 Handleiding geschreven
UWT Liner: Group 6 Lid van UWT Liner: Group 6
Community
3 Leden
1 handleiding geschreven
2 opmerkingen
Super helpful instructions. Especially mentioning which screws were different sizes, so I knew to keep the 3 different sizes for the back cover separated and noted which sizes went back where. Many thanks!
Albert Einstein - Antwoord
Great guide. Thanks!
weston.fisher - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 7,377
