Ga door naar hoofdinhoud
Asus VivoBook Max X541UV-BH71-CB Battery Replacement
Wat je nodig hebt
  1. Asus VivoBook Max X541UV-BH71-CB Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop upside down so the back of the laptop faces you.
  2. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: stap 2, afbeelding 1 van 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: stap 2, afbeelding 2 van 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the ten 1.2 mm screws attached to the back cover of the laptop.
  3. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: stap 3, afbeelding 1 van 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: stap 3, afbeelding 2 van 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: stap 3, afbeelding 3 van 3
    • Turn the laptop upright, then open the laptop so the screen faces you.
    • Use a prying tool between the keyboard and bottom grooves to partially remove the laptop backing.
    • Do not completely remove the laptop backing because there are ribbon cables connecting the two halves.
    • It is recommended to use a plastic prying tool rather than a metal prying tool because it could potentially damage the internals of the laptop.
  4. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: stap 4, afbeelding 1 van 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: stap 4, afbeelding 2 van 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: stap 4, afbeelding 3 van 3
    • Flip the retaining flaps on both keyboard ribbon cable ZIF sockets, then carefully pull the ribbon cables out of their sockets.
    • Carefully remove the keyboard panel from the base and set it aside.
  5. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: stap 5, afbeelding 1 van 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: stap 5, afbeelding 2 van 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: stap 5, afbeelding 3 van 3
    • Remove the two 1.2 mm screws holding the battery in place using the Phillips #00 screwdriver.
  6. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: stap 6, afbeelding 1 van 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: stap 6, afbeelding 2 van 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: stap 6, afbeelding 3 van 3
    • Carefully remove the battery using a plastic opening tool.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Vivek Rana
169 Reputatie
1 Handleiding geschreven
Één opmerking
Does anybody has a link to buy the battery replacement? Either original or generic. Thank you!
nea-k nanea - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 60
Altijd: 2,128
