Ga door naar hoofdinhoud
Asus VivoBook E203MA-TBCL432B Power Button Replacement
Wat je nodig hebt
  1. Asus VivoBook E203MA-TBCL432B Power Button Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Power Button Replacement: stap 2, afbeelding 1 van 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: stap 2, afbeelding 2 van 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Power Button Replacement: stap 3, afbeelding 1 van 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: stap 3, afbeelding 2 van 3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: stap 3, afbeelding 3 van 3
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Power Button Replacement, Power Button: stap 4, afbeelding 1 van 2 Asus VivoBook E203MA-TBCL432B Power Button Replacement, Power Button: stap 4, afbeelding 2 van 2
    • Remove the single connector by first pulling back the white tab and then pulling the connector out with the blue tab.
  5. Asus VivoBook E203MA-TBCL432B Power Button Replacement: stap 5, afbeelding 1 van 2 Asus VivoBook E203MA-TBCL432B Power Button Replacement: stap 5, afbeelding 2 van 2
    • Remove the single 2 mm screw with a Phillips #0 screwdriver.
  6. Asus VivoBook E203MA-TBCL432B Power Button Replacement: stap 6, afbeelding 1 van 1
    • Now that the power button component is free, lift it up and out of the laptop.
Conclusie
Jacob Aubertine
470 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S8-G1, Bailey Spring 2019 Lid van UMass Dartmouth, Team S8-G1, Bailey Spring 2019
UMASSD-BAILEY-S19S8G1
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 895
