Ga door naar hoofdinhoud
Asus V6800V Wireless Card Replacement
Wat je nodig hebt
  1. Asus V6800V Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 2 Asus V6800V Wireless Card Replacement, Battery: stap 1, afbeelding 2 van 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Wireless Card Replacement, Wireless Card: stap 2, afbeelding 1 van 2 Asus V6800V Wireless Card Replacement, Wireless Card: stap 2, afbeelding 2 van 2
    • Remove the six screws highlighted on the picture.
    • Once the screws are removed, pry open the panel with the pry tool.
    • It should now look like this.
  3. Asus V6800V Wireless Card Replacement: stap 3, afbeelding 1 van 2 Asus V6800V Wireless Card Replacement: stap 3, afbeelding 2 van 2
    • After removing that panel, locate the screw on the right as highlighted.
    • Remove that screw.
    • Pry open the side panel with the small prying tool as shown.
    • That panel should pop off and the wireless card will now be easily visible.
  4. Asus V6800V Wireless Card Replacement: stap 4, afbeelding 1 van 1
    • Place the small prying tool underneath the gold connector and gently apply pressure straight up until it pops off.
    • Repeat for the other one.
    • Place the gold connectors aside.
  5. Asus V6800V Wireless Card Replacement: stap 5, afbeelding 1 van 3 Asus V6800V Wireless Card Replacement: stap 5, afbeelding 2 van 3 Asus V6800V Wireless Card Replacement: stap 5, afbeelding 3 van 3
    • Locate the tabs that are holding the wireless card in place. These are highlighted in picture.
    • Place one finger on each tab and press each to the side away from the wireless card as shown.
    • The wireless card should pop up as shown. Pull up more with fingers to get more clearance.
  6. Asus V6800V Wireless Card Replacement: stap 6, afbeelding 1 van 2 Asus V6800V Wireless Card Replacement: stap 6, afbeelding 2 van 2
    • To remove the wireless card, pull the card directly out.
    • It should come out with just a little bit of pressure.
    • It should look as shown when removed.
Conclusie
Steven
32 Reputatie
2 handleidingen geschreven
Cal Poly, Team 2-9, Johann Summer 2010 Lid van Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 3,890
