Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Place the computer upside down.
Using your thumbs, slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
Using a Phillips #0 screwdriver, remove the two screws from the case.
Locate the four tabs above the F1, F10, INSERT, and between the F5 and F6 keys.
Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
Pull the keyboard up from the top at a 45 degree angle. Place it upside down on the touchpad.
Pull the wide ribbon cable laterally from its socket on the motherboard to free the keyboard.
Using a Phillips #0 screwdriver, remove the screws at the bottom of the chassis to remove the top panel.
Remove the six screws from below the keyboard with a Phillips #0 screwdriver.
Use your fingernails or a pry tool to gently separate both halves of the case. Begin at the front and work around the entire case.
Remove the internal cables from front to back.
Use your fingers to gently remove the cables from their sockets.
After separating the top and bottom halves of the case, lay them flat on the work area.
Remove the four screws using a Phillips #0 screwdriver.
Remove the protective metal plates with your hands.
Één andere persoon heeft deze handleiding voltooid.
