Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Place the computer upside down.
Using your thumbs, slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
Using a Phillips #0 screwdriver, remove the screws at the bottom of the chassis to remove the top panel.
Using a screwdriver, remove the screws that are highlighted in red.
Now, with your hands, remove the protective metal plates.
To reassemble your speakers, follow these instructions.
Één andere persoon heeft deze handleiding voltooid.
