Ga door naar hoofdinhoud
Asus V500CA-DB51T WiFi Card Replacement
Wat je nodig hebt
  1. Asus V500CA-DB51T WiFi Card Replacement, Battery: stap 1, afbeelding 1 van 2 Asus V500CA-DB51T WiFi Card Replacement, Battery: stap 1, afbeelding 2 van 2
    • The top left and right corners have .7 cm screws.
    • The two top-middle and four bottom are .4 cm screws.
    • The middle left and right are .8 cm screws.
    • Remove the screws using the Phillips #00 screwdriver.
  2. Asus V500CA-DB51T WiFi Card Replacement: stap 2, afbeelding 1 van 2 Asus V500CA-DB51T WiFi Card Replacement: stap 2, afbeelding 2 van 2
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Asus V500CA-DB51T WiFi Card Replacement: stap 3, afbeelding 1 van 1
    • Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
  4. Asus V500CA-DB51T WiFi Card Replacement: stap 4, afbeelding 1 van 2 Asus V500CA-DB51T WiFi Card Replacement: stap 4, afbeelding 2 van 2
    • Remove the tri-point screws that secure the battery to the casing.
    • All screws securing the battery in place are .5 cm tri-point screws.
  5. Asus V500CA-DB51T WiFi Card Replacement: stap 5, afbeelding 1 van 3 Asus V500CA-DB51T WiFi Card Replacement: stap 5, afbeelding 2 van 3 Asus V500CA-DB51T WiFi Card Replacement: stap 5, afbeelding 3 van 3
    • Use the opening tool to pop up the battery away from the casing.
  6. Asus V500CA-DB51T WiFi Card Replacement, WiFi Card: stap 6, afbeelding 1 van 2 Asus V500CA-DB51T WiFi Card Replacement, WiFi Card: stap 6, afbeelding 2 van 2
    • Locate the section of the device that houses the WiFi Card.
    • This should be a white, square-shaped object located just above the left end of the battery.
  7. Asus V500CA-DB51T WiFi Card Replacement: stap 7, afbeelding 1 van 2 Asus V500CA-DB51T WiFi Card Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect the black and white wires that are connected to the WiFi card by gently pulling them upward with a pair of tweezers.
    • Using the tweezers, gently pull the WiFi card out away from yourself.
    • If you try pulling up you could cause damage, so be sure to slowly and gently pull the card away from yourself.
Conclusie
Galen P Garofalo
670 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S6-G2, Rockett Fall 2017 Lid van UMass Dartmouth, Team S6-G2, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 273
