Ga door naar hoofdinhoud
Asus V500CA-DB51T Hard Drive Replacement
Wat je nodig hebt
  1. Asus V500CA-DB51T Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Asus V500CA-DB51T Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • The top left and right corners have .7 cm screws.
    • The two top-middle and four bottom are .4 cm screws.
    • The middle left and right are .8 cm screws.
    • Remove the screws using the Phillips #00 screwdriver.
  2. Asus V500CA-DB51T Hard Drive Replacement: stap 2, afbeelding 1 van 2 Asus V500CA-DB51T Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Asus V500CA-DB51T Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
  4. Asus V500CA-DB51T Hard Drive Replacement: stap 4, afbeelding 1 van 2 Asus V500CA-DB51T Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Remove the tri-point screws that secure the battery to the casing.
    • All screws securing the battery in place are .5 cm tri-point screws.
  5. Asus V500CA-DB51T Hard Drive Replacement: stap 5, afbeelding 1 van 3 Asus V500CA-DB51T Hard Drive Replacement: stap 5, afbeelding 2 van 3 Asus V500CA-DB51T Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Use the opening tool to pop up the battery away from the casing.
  6. Asus V500CA-DB51T Hard Drive Replacement, Hard Drive: stap 6, afbeelding 1 van 3 Asus V500CA-DB51T Hard Drive Replacement, Hard Drive: stap 6, afbeelding 2 van 3 Asus V500CA-DB51T Hard Drive Replacement, Hard Drive: stap 6, afbeelding 3 van 3
    • Remove the following screws securing the battery connector board to the logic board:
    • The red screws are size 2.3 cm T6 Torx
    • The orange screws are size 2.4 cm T6 Torx
  7. Asus V500CA-DB51T Hard Drive Replacement: stap 7, afbeelding 1 van 2 Asus V500CA-DB51T Hard Drive Replacement: stap 7, afbeelding 2 van 2
    • Remove the SSD (Solid State Drive) assembly from the upper case.
Conclusie
Galen P Garofalo
670 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S6-G2, Rockett Fall 2017 Lid van UMass Dartmouth, Team S6-G2, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 584
