Ga door naar hoofdinhoud
Asus UL80VT Motherboard Replacement
Wat je nodig hebt
  1. Asus UL80VT Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop so you can see the back side.
  2. Asus UL80VT Motherboard Replacement: stap 2, afbeelding 1 van 2 Asus UL80VT Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Identify the two slide locks below the battery. Slide them outward towards the unlock symbol. You should see a red mark that indicates that the battery is unlocked and is ready for removal.
  3. Asus UL80VT Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Now you can remove the battery while continuing to hold the right battery lock in the unlock position.
  4. Asus UL80VT Motherboard Replacement, Hard Drive: stap 4, afbeelding 1 van 3 Asus UL80VT Motherboard Replacement, Hard Drive: stap 4, afbeelding 2 van 3 Asus UL80VT Motherboard Replacement, Hard Drive: stap 4, afbeelding 3 van 3
    • Flip the computer over, and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
    • Lift the panel from the device.
  5. Asus UL80VT Motherboard Replacement: stap 5, afbeelding 1 van 2 Asus UL80VT Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Slide the hard drive away from the SATA connector and remove the hard drive from the device.
  6. Asus UL80VT Motherboard Replacement, RAM: stap 6, afbeelding 1 van 1
    • Flip computer over and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
  7. Asus UL80VT Motherboard Replacement: stap 7, afbeelding 1 van 3 Asus UL80VT Motherboard Replacement: stap 7, afbeelding 2 van 3 Asus UL80VT Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed.
  8. Asus UL80VT Motherboard Replacement, Keyboard: stap 8, afbeelding 1 van 2 Asus UL80VT Motherboard Replacement, Keyboard: stap 8, afbeelding 2 van 2
    • Open laptop so the keyboard is accessible.
    • Insert a plastic prying tool and push and then pull to release the keyboard from the device.
  9. Asus UL80VT Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Lift keyboard and remove ZIF connector cables.
    • Remove the keyboard from the device.
  10. Asus UL80VT Motherboard Replacement, Motherboard: stap 10, afbeelding 1 van 1
    • Remove the nine 5 mm screws using the Phillips #0 screwdriver.
  11. Asus UL80VT Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Flip the laptop over and remove nine 5 mm screws using the Phillips #0 screwdriver.
  12. Asus UL80VT Motherboard Replacement: stap 12, afbeelding 1 van 2 Asus UL80VT Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Use the iFixit opening tool to remove the cd drive on the left of the laptop.
  13. Asus UL80VT Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Use the same tool to remove the plastic top from the laptop.
  14. Asus UL80VT Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Remove the eight 3 mm screws using the Phillips #0 screwdriver.
    • Lift up the motherboard and disconnect all wires attaching the motherboard to the rest of the computer.
  15. Asus UL80VT Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Lift the motherboard out of the laptop and remove it from the device.
Conclusie
James DellaMorte
660 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S1-G5, Botvin Spring 2019 Lid van UMass Dartmouth, Team S1-G5, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G5
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 19
Altijd: 435
