Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide will take you through the process of replacing the optical drive in an Asus U56E-BBL6 laptop. You will need the correct replacement optical drive for your laptop to complete the installation.
Wat je nodig hebt
Locate the battery locking tabs on the upper right and left corner.
Press the tabs in towards each other.
Using a plastic opening tool, separate the optical drive from the laptop frame.
