Ga door naar hoofdinhoud
Inleiding
This guide will take you step by step in disassembling your laptop to access your motherboard. The process is quite involved as you will need to remove all other components surrounding it.
Onderdelen
Geen onderdelen opgegeven.
  1. Make sure you unplugged the laptop before you begin the replacement process.
    • Make sure you unplugged the laptop before you begin the replacement process.
    • Locate the battery locking tabs on the upper right and left corner.
    • Press the tabs in towards each other.
  2. Pull the battery outwards to  remove it.
    • Pull the battery outwards to remove it.
  3. Using a Phillips #00 screwdriver, remove the screws. Using a Phillips #00 screwdriver, remove the screws.
    • Using a Phillips #00 screwdriver, remove the screws.
  4. Lift backplate and remove from the case.
    • Lift backplate and remove from the case.
  5. Once inside the panel, locate your RAM sticks.
    • Once inside the panel, locate your RAM sticks.
  6. This device is embedded with  two RAM sticks. Push the metal brackets carefully to release and remove the RAM stick .
    • This device is embedded with two RAM sticks.
    • Push the metal brackets carefully to release and remove the RAM stick .
  7. Repeat the previous step for removing the other RAM stick. Repeat the previous step for removing the other RAM stick.
    • Repeat the previous step for removing the other RAM stick.
  8. Using a Phillips #00, remove the four screws.
    • Using a Phillips #00, remove the four screws.
  9. PC Laptop Batteries
    Batteries for all the top PC brands, backed by our Quality Guarantee.
    Nu winkelen
    PC Laptop Batteries
    Nu winkelen
  10. Using a Phillips #00 screwdriver, remove the screws. Using a Phillips #00 screwdriver, remove the screws.
  11. Use a plastic opening tool around the entire edge.
    • Use a plastic opening tool around the entire edge.
    • Separate the case from the keyboard.
  12. Ensure the laptop is face up for this step.
    • Ensure the laptop is face up for this step.
    • Gently lift the keyboard from the base of the laptop.
    • Be careful of the ribbon cables connecting the keyboard.
  13. Gently tug the ribbon cables free from their slots.
    • Gently tug the ribbon cables free from their slots.
  14. Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop. Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop.
    • Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop.
  15. Using a plastic opening tool, separate the optical drive from the laptop frame.
    • Using a plastic opening tool, separate the optical drive from the laptop frame.
    • Be careful to leverage the plastic opening tool against the frame and not the motherboard as this may cause damage.
  16. Remove the optical drive by sliding it out from the case.
    • Remove the optical drive by sliding it out from the case.
  17. Using a Phillips #00 screwdriver, remove the three screws.
    • Using a Phillips #00 screwdriver, remove the three screws.
  18. Lift up the ribbon cable connector on the bottom right corner. Gently pry the cable away from the connection. Gently pry the cable away from the connection.
    • Lift up the ribbon cable connector on the bottom right corner.
    • Gently pry the cable away from the connection.
  19. Remove the 4 pronged connection on the bottom right corner of the motherboard. Remove the 4 pronged connection on the bottom right corner of the motherboard.
    • Remove the 4 pronged connection on the bottom right corner of the motherboard.
  20. Using a Phillips #0 screwdriver, remove the two screws. Holding the board firmly with two fingers, pull outward, disconnecting it from the contacts.
    • Using a Phillips #0 screwdriver, remove the two screws.
    • Holding the board firmly with two fingers, pull outward, disconnecting it from the contacts.
  21. Repeat the previous step and remove the two wired connection next to the card.
    • Repeat the previous step and remove the two wired connection next to the card.
  22. Remove the cable at the top left of the motherboard. This cable is held in by a magnetic connection. Be sure to lift up and away when disconnecting.
    • Remove the cable at the top left of the motherboard.
    • This cable is held in by a magnetic connection. Be sure to lift up and away when disconnecting.
  23. Using both hands, lift the motherboard up and out from the case Using both hands, lift the motherboard up and out from the case
    • Using both hands, lift the motherboard up and out from the case
Conclusie
Josiah Allard
705 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S2-G8, Peak Fall 2018 Lid van UMass Dartmouth, Team S2-G8, Peak Fall 2018
UMASSD-PEAK-F18S2G8
3 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 3
Altijd: 68
