Ga door naar hoofdinhoud
Asus Transformer T100 Power Button Replacement
Wat je nodig hebt
  1. Asus Transformer T100 Power Button Replacement, Rear Cover: stap 1, afbeelding 1 van 2 Asus Transformer T100 Power Button Replacement, Rear Cover: stap 1, afbeelding 2 van 2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Power Button Replacement: stap 2, afbeelding 1 van 2 Asus Transformer T100 Power Button Replacement: stap 2, afbeelding 2 van 2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
  3. Asus Transformer T100 Power Button Replacement: stap 3, afbeelding 1 van 1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Power Button Replacement: stap 4, afbeelding 1 van 2 Asus Transformer T100 Power Button Replacement: stap 4, afbeelding 2 van 2
    • Remove the rear casing.
  5. Asus Transformer T100 Power Button Replacement, Power Button: stap 5, afbeelding 1 van 2 Asus Transformer T100 Power Button Replacement, Power Button: stap 5, afbeelding 2 van 2
    • Using a flathead screwdriver, pry the button connection up.
    • There will be some resistance. Slowly increase the pressure until the button pops off.
Conclusie
Use a small amount of epoxy or other adhesive to attach the new button.
9 andere personen hebben deze handleiding voltooid.
Taylor Pantiga
1.596 Reputatie
6 handleidingen geschreven
Cal Poly, Team 13-31, Maness Spring 2014 Lid van Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 Leden
4 opmerkingen
Where can you get a button?
dsmit26 - Antwoord
Anyone have a link to get the button?
Seb bar -
hi
i got a major problem ....mine is tf300t and when i got the cover out the power button came out with it what should i do i can't reattach it with my bare hands plsss help me !!!!
kiko - Antwoord
The asus computer fell, well the screen took a beating, touch no longer works and sometimes the tablet senses as if it were touched making it difficult to perform tasks clicking etc.
The keyboard is partially working. The computer was still operation like for reading and watching to some extent
The battery ran out and found out that the power button isn't clicking really, no feedback.
Apart from the obvious problems, I'd like to first turn the tablet on after charging (have some files on it ti download). From the depiction is there a chance popping the tablet open would be of assistance? Could the screen though fall apart following opening it up? Any suggestions? Your assistance is most appreciated
Thank you
100 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 38
Altijd: 23,256
