Ga door naar hoofdinhoud
Asus Transformer Pad TF103C Speakers Replacement
Wat je nodig hebt
  1. Asus Transformer Pad TF103C Speakers Replacement, Speakers: stap 1, afbeelding 1 van 1
    • Shut down your tablet before beginning the repair.
    • Insert the plastic opening tool on the side of the tablet.
    • Gently pull upwards and carefully pry open the tablet.
  2. Asus Transformer Pad TF103C Speakers Replacement: stap 2, afbeelding 1 van 1
    • Slide the tool around all four sides of the tablet while gently pulling the tool up.
  3. Asus Transformer Pad TF103C Speakers Replacement: stap 3, afbeelding 1 van 1
    • Remove the back cover once you have loosened it from the tablet. Set the back cover aside.
    • Rotate the tablet to match the picture.
  4. Asus Transformer Pad TF103C Speakers Replacement: stap 4, afbeelding 1 van 1
    • Carefully unplug the rainbow cable from the motherboard.
  5. Asus Transformer Pad TF103C Speakers Replacement: stap 5, afbeelding 1 van 1
    • Use the plastic opening tool to carefully pry the battery out from the frame.
  6. Asus Transformer Pad TF103C Speakers Replacement: stap 6, afbeelding 1 van 2 Asus Transformer Pad TF103C Speakers Replacement: stap 6, afbeelding 2 van 2
    • Use the JIS #000 screwdriver to remove the four screws.
    • Keep the screws together and organized. (Label the screws, if necessary).
  7. Asus Transformer Pad TF103C Speakers Replacement: stap 7, afbeelding 1 van 1
    • Take the ground wire out from the top of the TF103C-L (left) speaker.
    • If you pull on the wire too much it will break off.
    • If you break the wire off you can solder it back on.
  8. Asus Transformer Pad TF103C Speakers Replacement: stap 8, afbeelding 1 van 1
    • Remove the tape and unplug the wire that is connected to both of the speakers.
  9. Asus Transformer Pad TF103C Speakers Replacement: stap 9, afbeelding 1 van 2 Asus Transformer Pad TF103C Speakers Replacement: stap 9, afbeelding 2 van 2
    • Remove the two speakers from the frame.
Conclusie
Tyler Ellis
668 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 3-6, Shastany Fall 2015 Lid van UMass Dartmouth, Team 3-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G6
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 454
