Ga door naar hoofdinhoud
Asus Transformer Pad Infinity LCD Display Replacement
Wat je nodig hebt
  1. Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: stap 1, afbeelding 1 van 3 Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: stap 1, afbeelding 2 van 3 Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: stap 1, afbeelding 3 van 3
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  2. Asus Transformer Pad Infinity LCD Display Replacement: stap 2, afbeelding 1 van 1
    • Remove the 4 screws around the metal portion of the screen (this is the LCD display).
  3. Asus Transformer Pad Infinity LCD Display Replacement: stap 3, afbeelding 1 van 1
    • Peel the orange ribbon back (it has adhesive sticking itself to the black electric tape looking stuff surrounding the metal portion).
  4. Asus Transformer Pad Infinity LCD Display Replacement: stap 4, afbeelding 1 van 1
    • Carefully place a preferably plastic tool between the glass portion and the electric tape looking stuff and pry off the screen from that portion.
    • Note: Take care as you’re dealing directly with with the glass and the way your touch input gets into the device.
  5. Asus Transformer Pad Infinity LCD Display Replacement: stap 5, afbeelding 1 van 1
    • Once removed, replace the LCD display back onto the glass screen (the new screen may or may not have new adhesive depending on where you got it.
    • If it doesn’t, make sure you secure it with the screws safely).
Conclusie
Allison Poh
549 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 1,231
