Ga door naar hoofdinhoud
Inleiding
Replacing the battery involves opening up the device. Prerequisites; follow the Asus Transformer Pad Infinity Teardown link up to step 6 to remove the screen.
  1. Disconnect the long silver ribbon connector from the screen. Remove the orange ribbon connector with the two connections. Remove the orange ribbon connector with the two connections.
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  2. Disconnect the battery from the big motherboard.
    • Disconnect the battery from the big motherboard.
  3. Unscrew all eight screws connecting the battery to the case.
    • Unscrew all eight screws connecting the battery to the case.
    • Remove the battery.
  4. Place the new battery in the same spot as the old battery.
    • Place the new battery in the same spot as the old battery.
    • Screw the eight screws back in place to connect the new battery to the case.
Conclusie
Allison Poh
549 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Leden
10 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 2,412
