Inleiding
If your screen is damaged or unresponsive then a replacement may be in order. Follow this guide to do it yourself in a few easy steps.
Wat je nodig hebt
The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
Gently remove the Wifi cables hooked to the rim of the battery
Remove the battery
Open your flip book so that the screen faces towards you. You will notice 2 rubber pads at the base of the screen.
Using a metal spudger, lift the rubber pads off to find 2 screen 3mm screws. Unscrew these 3mm screw with a phillips head J000 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
