Inleiding
Track pads can go bad after repetitive use as well as any built up moisture, dust, or crumbs. You may need to replace your Asus TUF Gaming FX705G track pad if it is lagging, jammed, or disabled. Before you replace your track pad, check your owner’s manual, to ensure it is not a technical issue, and to take cautionary steps when working on the track pad.
Wat je nodig hebt
Één andere persoon heeft deze handleiding voltooid.
