Ga door naar hoofdinhoud
Asus TUF Gaming FX705G Speakers Replacement
Wat je nodig hebt
  1. Asus TUF Gaming FX705G Speakers Replacement, Back Cover: stap 1, afbeelding 1 van 2 Asus TUF Gaming FX705G Speakers Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Speakers Replacement: stap 2, afbeelding 1 van 2 Asus TUF Gaming FX705G Speakers Replacement: stap 2, afbeelding 2 van 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Speakers Replacement, Battery: stap 3, afbeelding 1 van 2 Asus TUF Gaming FX705G Speakers Replacement, Battery: stap 3, afbeelding 2 van 2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Speakers Replacement: stap 4, afbeelding 1 van 2 Asus TUF Gaming FX705G Speakers Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Speakers Replacement, Speakers: stap 5, afbeelding 1 van 2 Asus TUF Gaming FX705G Speakers Replacement, Speakers: stap 5, afbeelding 2 van 2
    • Use your fingers to lift the speaker from the housing and follow the wire path carefully, lifting the wire out of place around the base.
  6. Asus TUF Gaming FX705G Speakers Replacement: stap 6, afbeelding 1 van 1
    • Repeat the removal process on the second speaker, being careful not to rip the wire.
  7. Asus TUF Gaming FX705G Speakers Replacement: stap 7, afbeelding 1 van 1
    • With the second speaker removed from the track, carefully disconnect the three wires from the insert on the motherboard.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 1,528
