Ga door naar hoofdinhoud
Asus TUF Gaming FX505DY Motherboard Replacement
Wat je nodig hebt
  1. Asus TUF Gaming FX505DY Motherboard Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. Asus TUF Gaming FX505DY Motherboard Replacement: stap 2, afbeelding 1 van 2 Asus TUF Gaming FX505DY Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. Asus TUF Gaming FX505DY Motherboard Replacement: stap 3, afbeelding 1 van 2 Asus TUF Gaming FX505DY Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. Asus TUF Gaming FX505DY Motherboard Replacement: stap 4, afbeelding 1 van 2 Asus TUF Gaming FX505DY Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. Asus TUF Gaming FX505DY Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 3 Asus TUF Gaming FX505DY Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 3 Asus TUF Gaming FX505DY Motherboard Replacement, Motherboard: stap 5, afbeelding 3 van 3
    • With a Phillips 0-bit screwdriver, remove eight 5.0 mm screws on the silver brackets
    • With a Phillips 0-bit screwdriver, remove two 5.0 mm screws holding the edge of the fans in place
  6. Asus TUF Gaming FX505DY Motherboard Replacement: stap 6, afbeelding 1 van 3 Asus TUF Gaming FX505DY Motherboard Replacement: stap 6, afbeelding 2 van 3 Asus TUF Gaming FX505DY Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Gently remove all power cables connecting the fans to the motherboard.
    • Once all cables and screws are removed, carefully lift up and remove the fans and heat sink
  7. Asus TUF Gaming FX505DY Motherboard Replacement: stap 7, afbeelding 1 van 2 Asus TUF Gaming FX505DY Motherboard Replacement: stap 7, afbeelding 2 van 2
    • With a Phillips 0-bit screwdriver, unscrew four 5.0 mm screws.
    • Disconnect the primary connector cable located at the bottom left and carefully remove the module.
  8. Asus TUF Gaming FX505DY Motherboard Replacement: stap 8, afbeelding 1 van 3 Asus TUF Gaming FX505DY Motherboard Replacement: stap 8, afbeelding 2 van 3 Asus TUF Gaming FX505DY Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Removing the ram, push down unto the ram and move the metal locking tabs to the side by lifting upward slightly then moving each to their outside.
    • Pull the ram out toward the angle when the ram is sticking up at an angle when released.
  9. Asus TUF Gaming FX505DY Motherboard Replacement: stap 9, afbeelding 1 van 2 Asus TUF Gaming FX505DY Motherboard Replacement: stap 9, afbeelding 2 van 2
    • With a Phillips 0-bit screwdriver, unscrew four 5.0 mm top screws holding the hard drive in place.
    • Pinch the top left corner with your finger and slide the harddrive out of its casing.
  10. Asus TUF Gaming FX505DY Motherboard Replacement: stap 10, afbeelding 1 van 2 Asus TUF Gaming FX505DY Motherboard Replacement: stap 10, afbeelding 2 van 2
    • With a Phillips 0-bit screwdriver, unscrew two 5.0 mm screws holding SSD down to the motherboard on the right side of the board
    • Slide module out of protective casing to remove piece.
  11. Asus TUF Gaming FX505DY Motherboard Replacement: stap 11, afbeelding 1 van 3 Asus TUF Gaming FX505DY Motherboard Replacement: stap 11, afbeelding 2 van 3 Asus TUF Gaming FX505DY Motherboard Replacement: stap 11, afbeelding 3 van 3
    • With a size 0 Phillips screwdriver, unscrew three center 5 mm screws securing the board in place.
    • Carefully lift the board and place in a safe area.
Conclusie
Één opmerking
Can I change the motherboard of my laptop? I have the model FX505DY (Ryzen 5 3550H, Radeon RX 560X, 17.3 inches). I would like to change it for the FX505DT model (Ryzen 7 3570H, GTX 1650, 17.3 inches)
Luis Nox - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 71
Altijd: 1,327
