Ga door naar hoofdinhoud
Asus TUF Gaming FX505DY Heat Sink & Fan Replacement
Wat je nodig hebt
  1. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: stap 2, afbeelding 1 van 2 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: stap 3, afbeelding 1 van 2 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: stap 3, afbeelding 2 van 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: stap 4, afbeelding 1 van 2 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: stap 4, afbeelding 2 van 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement, Heat Sink & Fan: stap 5, afbeelding 1 van 3 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement, Heat Sink & Fan: stap 5, afbeelding 2 van 3 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement, Heat Sink & Fan: stap 5, afbeelding 3 van 3
    • With a Phillips 0-bit screwdriver, remove eight 5.0 mm screws on the silver brackets
    • With a Phillips 0-bit screwdriver, remove two 5.0 mm screws holding the edge of the fans in place
  6. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: stap 6, afbeelding 1 van 3 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: stap 6, afbeelding 2 van 3 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: stap 6, afbeelding 3 van 3
    • Disconnect two power cables connecting fans to the motherboard.
    • Once all cables and screws are removed, carefully lift up and remove the fans and heat sink
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 69
Altijd: 1,311
