Inleiding
For those experiencing picture clarity or no response from the rear camera this guide is for you. The Asus TF300T Android Tablet has a rear facing rear camera that is sensitive to pressure and other factors that may damage it. This guide will instruct the user of how to successfully replace the rear camera.
  1. Begin the process by making sure that the dock is disconnected and the power is turned off. Start by using the plastic opening tool on the side opposite the dock/ charging port. Begin to open the device along the short sides of the tablet. When you have reached the side with the charging/ dock port be gentle with the opening tool due to the thinner plastic that could be broken with excessive force.
    • Begin the process by making sure that the dock is disconnected and the power is turned off.
    • Start by using the plastic opening tool on the side opposite the dock/ charging port. Begin to open the device along the short sides of the tablet.
    • When you have reached the side with the charging/ dock port be gentle with the opening tool due to the thinner plastic that could be broken with excessive force.
    • Once the opening tools have completely made their way around the device use the spudger to separate the back panel from the screen and expose the inside.
  2. The Asus Transformer series tablets have a hard power switch. This should be turned off before working on the tablet.
    • The Asus Transformer series tablets have a hard power switch. This should be turned off before working on the tablet.
    • Locate the power switch near the power button on the top left. Use a tool to slide it to the position marked 'off'
      • For many repairs, like replacing the screen or digitizer, you do not need to remove the battery once you hve turned the tablet off. Be very careful not to short anything out with metal tools!
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  4. Using the Phillips #00 screwdriver remove all of the screws connecting the battery to the mother board. Once the initial screws have been removed as indicated by the photo, use the spudger to remove the cover concealing the the clips for the dock sensor ans a few more screws. Again remove the screws with the same screwdriver and use the spudger to disconnect the spudger sesors from their respective clips.
    • Using the Phillips #00 screwdriver remove all of the screws connecting the battery to the mother board.
    • Once the initial screws have been removed as indicated by the photo, use the spudger to remove the cover concealing the the clips for the dock sensor ans a few more screws.
    • Again remove the screws with the same screwdriver and use the spudger to disconnect the spudger sesors from their respective clips.
    • Once the battery is freed use the spudger to remove the battery from its spot
  5. Once the back panel is exposed, use the tweezers or  thespudger to lift the camera from its spot. Lift from the gold clip and not from the camera itself.
    • Once the back panel is exposed, use the tweezers or thespudger to lift the camera from its spot.
      • Lift from the gold clip and not from the camera itself.
Conclusie
Jonathan Barros
1.183 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 2-6, Duarte Fall 2014 Lid van UMass Dartmouth, Team 2-6, Duarte Fall 2014
UMASSD-DUARTE-F14S2G6
4 Leden
10 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 3
Altijd: 592
