Ga door naar hoofdinhoud
Asus TF300T Tablet Motherboard Replacement
Wat je nodig hebt
  1. Asus TF300T Tablet Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 Asus TF300T Tablet Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Disconnect the dock and make sure the power is turned of.
    • Use plastic opening tool to pry screen up and remove from outer casing.
    • Be gentle with the plastic opening tool when you reached the charging port as the thinner plastic could be broken easily.
  2. Asus TF300T Tablet Motherboard Replacement: stap 2, afbeelding 1 van 3 Asus TF300T Tablet Motherboard Replacement: stap 2, afbeelding 2 van 3 Asus TF300T Tablet Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Pull up on the black circuit board protector.
    • Turn off the hard power switch before working with the tablet. Use a tool to slide the switch to the position marked "off".
    • For most of the replacement operation, you do not have to remove the battery once you turned off the switch. Make sure that you do not short anything with the metal tools.
  3. Asus TF300T Tablet Motherboard Replacement: stap 3, afbeelding 1 van 2 Asus TF300T Tablet Motherboard Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a Phillips #00 Screwdriver to remove nine 3mm screws that is connected to the motherboard.
    • Use tweezers to remove connected part as shown in the picture.
  4. Asus TF300T Tablet Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the motherboard using the plastic opening tool gently.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Khairuz Zaki Md Rujhan
461 Reputatie
3 handleidingen geschreven
IUPUI, Team S2-G2, Wilson Summer 2017 Lid van IUPUI, Team S2-G2, Wilson Summer 2017
IUPUI-WILSON-SU17S2G2
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 24
Altijd: 1,507
