Ga door naar hoofdinhoud
Asus S500 USB, Headphone, and SD card Port board replacement
Wat je nodig hebt
  1. Asus S500 USB, Headphone, and SD card Port board replacement, USB, Headphone, and SD card Ports: stap 1, afbeelding 1 van 1
    • Unscrew the 10 screws on the back cover
  2. Asus S500 USB, Headphone, and SD card Port board replacement: stap 2, afbeelding 1 van 1
    • Remove back cover (pry open along the grey/black line, they are held together by clips)
  3. Asus S500 USB, Headphone, and SD card Port board replacement: stap 3, afbeelding 1 van 1
    • Lift up tab and pull out the connector
    • Unscrew the 4 screws
    • Open up the screen (as you would to open up the laptop), and in doing so the metal piece will open up.
    • Jostle the ports and remove the small board.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Isaac Lemus
232 Reputatie
1 Handleiding geschreven
2 opmerkingen
where can i buy the usb mic part?
jorg123 - Antwoord
I have a [newish] 14” Asus 3 [Blue Al./gold trim]. One of my grandchildren has wrecked one of the usb 3.1 sockets on the right [Output] side.
Is it possible to renew this socket? I have all the tools + mini soldering iron. I could connect the remaining one to a usb hub I suppose but it’s an expensive machine and I would rather it be repaired.
Any help/advice very much appreciated. Regards - Denis
Denis TRAYNOR - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 3,675
