Inleiding
This guide will teach you how to remove and replace the CDC/DVD drive in case it became inoperable.
Wat je nodig hebt
Flip the laptop over so the backside is facing upwards.
Using both hands, slide the lock mechanisms outwards and pull up to remove the battery.
Remove the nine 15.4mm Phillips #00 screws.
Remove the four 8.7mm Phillips #00 screws from the hard drive mounting bracket.
Remove the hard drive bracket.
Bijna klaar!
Conclusie
