Inleiding
The fan is responsible for keeping the computer’s internal components from over heating and being destroyed. If your computer tends to overheat, use this guide to remove it and check if it needs to be cleaned or replaced.
Wat je nodig hebt
Remove the 1.6 mm and 9 mm screws from the back panel using the Phillips #1 screwdriver.
Bijna klaar!
Conclusie
