Ga door naar hoofdinhoud
Asus ROG Strix GL702VM-BHI7N09 Battery Replacement
Wat je nodig hebt
  1. Asus ROG Strix GL702VM-BHI7N09 Battery Replacement, Back Panel: stap 1, afbeelding 1 van 2 Asus ROG Strix GL702VM-BHI7N09 Battery Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Battery Replacement: stap 2, afbeelding 1 van 3 Asus ROG Strix GL702VM-BHI7N09 Battery Replacement: stap 2, afbeelding 2 van 3 Asus ROG Strix GL702VM-BHI7N09 Battery Replacement: stap 2, afbeelding 3 van 3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Unplug the battery from the motherboard.
  4. Asus ROG Strix GL702VM-BHI7N09 Battery Replacement: stap 4, afbeelding 1 van 3 Asus ROG Strix GL702VM-BHI7N09 Battery Replacement: stap 4, afbeelding 2 van 3 Asus ROG Strix GL702VM-BHI7N09 Battery Replacement: stap 4, afbeelding 3 van 3
    • Unscrew the 3.8 mm Phillips #1 screw on the top right hand corner of the battery.
    • Lift battery from laptop frame.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Gunnar Hudson
248 Reputatie
2 handleidingen geschreven
Één opmerking
Cheers mate! Worked like a %#*@. Built lots of PCs in my time but this is the first time I’ve taken a laptop apart. I should mention: there are 4 screws holding the battery in rather than the 1 you mention in this guide.
Collin MacQuarrie - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 63
Altijd: 9,435
