Ga door naar hoofdinhoud
Asus ROG GL551J Screen Replacement
Wat je nodig hebt
  1. Asus ROG GL551J Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Screen Replacement: stap 2, afbeelding 1 van 1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Screen Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery out.
  4. Asus ROG GL551J Screen Replacement, Screen: stap 4, afbeelding 1 van 2 Asus ROG GL551J Screen Replacement, Screen: stap 4, afbeelding 2 van 2
    • Use a plastic opening tool to remove the plastic hinge covers on either side of the laptop.
  5. Asus ROG GL551J Screen Replacement: stap 5, afbeelding 1 van 2 Asus ROG GL551J Screen Replacement: stap 5, afbeelding 2 van 2
    • Remove the middle screws located on either side of the display.
  6. Asus ROG GL551J Screen Replacement: stap 6, afbeelding 1 van 2 Asus ROG GL551J Screen Replacement: stap 6, afbeelding 2 van 2
    • Use a plastic opening tool to pop out the bezel from all four sides, then lift it out of the frame.
    • When doing this in reverse during reassembly, try closing the laptop and applying pressure to reattach the bezel snaps.
  7. Asus ROG GL551J Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove the screws at each corner of the display.
  8. Asus ROG GL551J Screen Replacement: stap 8, afbeelding 1 van 2 Asus ROG GL551J Screen Replacement: stap 8, afbeelding 2 van 2
    • Remove the connector from the display by pulling the wire downwards.
    • Be sure to take note of the orientation of the connector when unplugging and plugging in.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Thien Vu
412 Reputatie
2 handleidingen geschreven
USF Tampa, Team 5-4, Lacy Spring 2017 Lid van USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
4 Leden
5 handleidingen geschreven
Één opmerking
Hey, I am having issues putting the plastic hinge caps back on after I'm done. I know there is a right one and a left one but I just don't know how to pop them back into place. Starting to get a bit desperate. Could anyone give me some tips?
Thanks!
Teodor Andonov - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 3,036
