Inleiding
This guide demonstrates the step-by-step removal of the Asus ROG G751JL-DS71 screen. Before proceeding, unplug your device from its power source.
Wat je nodig hebt
Lift the rubber cover found on the bottom of the laptop.
Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
Lift away the metal housings from each side of the laptop.
Use a pair of tweezers to carefully disconnect the pin connector.
Één andere persoon heeft deze handleiding voltooid.
