Ga door naar hoofdinhoud
Asus ROG G751JL-BSI7T28 Speaker Replacement
Wat je nodig hebt
  1. Asus ROG G751JL-BSI7T28 Speaker Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 2, afbeelding 1 van 3 Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 2, afbeelding 2 van 3 Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 2, afbeelding 3 van 3
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 Speaker Replacement, Display Assembly: stap 3, afbeelding 1 van 2 Asus ROG G751JL-BSI7T28 Speaker Replacement, Display Assembly: stap 3, afbeelding 2 van 2
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 4, afbeelding 1 van 2 Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 5, afbeelding 1 van 3 Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 5, afbeelding 2 van 3 Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 5, afbeelding 3 van 3
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 6, afbeelding 1 van 3 Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 6, afbeelding 2 van 3 Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 6, afbeelding 3 van 3
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 7, afbeelding 1 van 2 Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 7, afbeelding 2 van 2
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
  8. Asus ROG G751JL-BSI7T28 Speaker Replacement, Keyboard Assembly: stap 8, afbeelding 1 van 2 Asus ROG G751JL-BSI7T28 Speaker Replacement, Keyboard Assembly: stap 8, afbeelding 2 van 2
    • Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
    • Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
    • Remove the keyboard from the laptop.
  9. Asus ROG G751JL-BSI7T28 Speaker Replacement, Speaker: stap 9, afbeelding 1 van 2 Asus ROG G751JL-BSI7T28 Speaker Replacement, Speaker: stap 9, afbeelding 2 van 2
    • Flip the SD card reader's retaining arm up.
    • Remove the SD card reader's power/data ribbon cable.
  10. Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 10, afbeelding 1 van 3 Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 10, afbeelding 2 van 3 Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 10, afbeelding 3 van 3
    • Remove the speaker's power/data cable.
  11. Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 11, afbeelding 1 van 2 Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 11, afbeelding 2 van 2
    • Remove four 3mm Phillips #0 screws from the speaker.
    • Remove three 3mm Phillips #0 screws from the SD card reader.
  12. Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 12, afbeelding 1 van 3 Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 12, afbeelding 2 van 3 Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 12, afbeelding 3 van 3
    • Remove the SD card reader.
  13. Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 13, afbeelding 1 van 3 Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 13, afbeelding 2 van 3 Asus ROG G751JL-BSI7T28 Speaker Replacement: stap 13, afbeelding 3 van 3
    • Remove the speaker from the laptop.
Conclusie
Dylan Michael Leonard
423 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S1-G1, Barthe Fall 2019 Lid van UMass Dartmouth, Team S1-G1, Barthe Fall 2019
UMASSD-BARTHE-F19S1G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 193
