Inleiding
This guide will demonstrate how to replace the fan in the Asus ROG G751JL-BSI7T28 laptop. The fan of a computer is critical to keeping the device cool, making its performance and longevity better. Symptoms of a faulty fan can include frequent overheating during heavy or normal computer use.
This guide is compatible with the following ASUS models: G751, G751J, G751JM, G751JT, G751JL, and G751JY.
Before beginning, make sure to power off your device before starting this guide to prevent any electrical injuries or damage to your computer.
Wat je nodig hebt
With the laptop closed, turn it upside-down so the bottom is facing up toward you.
Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
Remove the keyboard from the laptop.
