Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Use this guide if you are having troubles getting your speakers to work at optimal performance or if there is no sound coming out of your speakers at all.
Onderdelen
Geen onderdelen opgegeven.
  1. Using a plastic opening tool, remove the two rubber tabs circled in red. Using a plastic opening tool, remove the two rubber tabs circled in red.
    • Using a plastic opening tool, remove the two rubber tabs circled in red.
  2. Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed. Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed.
    • Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed.
  3. Slide the tab to pop the battery out of its holder. Pull the battery out of its slot.
    • Slide the tab to pop the battery out of its holder.
    • Pull the battery out of its slot.
  4. Remove the three 4mm Phillips #2 screws from the open battery slot as shown. Remove the two 5mm Phillips #2 screws.
    • Remove the three 4mm Phillips #2 screws from the open battery slot as shown.
    • Remove the two 5mm Phillips #2 screws.
  5. Begin prying up on the plate as shown in the pictures. Begin prying up on the plate as shown in the pictures. Begin prying up on the plate as shown in the pictures.
    • Begin prying up on the plate as shown in the pictures.
  6. Detach the single connector using your plastic opening tool.
    • Detach the single connector using your plastic opening tool.
    • Remove the speaker bar.
Conclusie
Tanner
796 Reputatie
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 145
