Ga door naar hoofdinhoud
Asus ROG G750JM-BSI7N23 Motherboard Replacement
Wat je nodig hebt
  1. Asus ROG G750JM-BSI7N23 Motherboard Replacement, Soundbar/speaker: stap 1, afbeelding 1 van 2 Asus ROG G750JM-BSI7N23 Motherboard Replacement, Soundbar/speaker: stap 1, afbeelding 2 van 2
    • Using a plastic opening tool, remove the two rubber tabs circled in red.
  2. Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 2, afbeelding 1 van 2 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed.
  3. Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 3, afbeelding 1 van 2 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Slide the tab to pop the battery out of its holder.
    • Pull the battery out of its slot.
  4. Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 4, afbeelding 1 van 2 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the three 4mm Phillips #2 screws from the open battery slot as shown.
    • Remove the two 5mm Phillips #2 screws.
  5. Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 5, afbeelding 1 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 5, afbeelding 2 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Begin prying up on the plate as shown in the pictures.
  6. Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Detach the single connector using your plastic opening tool.
    • Remove the speaker bar.
  7. Asus ROG G750JM-BSI7N23 Motherboard Replacement, Back Plate: stap 7, afbeelding 1 van 1
    • With the computer upside down, lift up on the rubber cap on the back plate to access the captive Phillips #2 screw.
  8. Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Retract the Phillips #2 screw until the cover is loose.
    • The screw will not come all the way out.
  9. Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 9, afbeelding 1 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 9, afbeelding 2 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Pry around the edges of the plate using a plastic opening tool until the plate is removed.
  10. Asus ROG G750JM-BSI7N23 Motherboard Replacement, Keyboard: stap 10, afbeelding 1 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement, Keyboard: stap 10, afbeelding 2 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement, Keyboard: stap 10, afbeelding 3 van 3
    • Remove the six 8mm Phillips #2 screws to remove the display.
    • Remove the two 4mm Phillips #2 screws.
  11. Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 11, afbeelding 1 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 11, afbeelding 2 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Remove the four rubber tabs circled in green on the bottom of the device.
    • Remove the five 4mm #2 Phillips screws.
    • Remove the two 8mm #2 Phillips screws.
    • Remove the two 1cm #2 Phillips screws.
  12. Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 12, afbeelding 1 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 12, afbeelding 2 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Pry around the keyboard on the top topside as shown to remove it from shell.
  13. Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 13, afbeelding 1 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 13, afbeelding 2 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 13, afbeelding 3 van 3
    • Remove the four connectors using your pry tool.
    • The keyboard will now be separated from the main computer.
  14. Asus ROG G750JM-BSI7N23 Motherboard Replacement, Motherboard: stap 14, afbeelding 1 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement, Motherboard: stap 14, afbeelding 2 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement, Motherboard: stap 14, afbeelding 3 van 3
    • First, remove the two 7mm #2 Phillips screws circled in red to fold the silver plate over.
    • Remove all the connectors shown in the orange squares. You may need to use your plastic opening tool for the smaller ones.
  15. Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 15, afbeelding 1 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 15, afbeelding 2 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Remove the three #2 Phillips screws from the small wireless card located in the top left.
  16. Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 16, afbeelding 1 van 2 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 16, afbeelding 2 van 2
    • Remove the three #2 Phillips screws from the small power button card in the top right.
  17. Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 17, afbeelding 1 van 1
    • Remove the two #2 Phillips screws for the audio card located in the bottom right.
  18. Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 18, afbeelding 1 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 18, afbeelding 2 van 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 18, afbeelding 3 van 3
    • Remove all 8mm #2 Phillips screws .
    • Remove all 2mm #2 Phillips screws.
    • Remove all 3mm #2 Phillips screws.
    • Remove all 7mm #2 Phillips screws.
    • Remove all 4mm #2 Phillips screws.
  19. Asus ROG G750JM-BSI7N23 Motherboard Replacement: stap 19, afbeelding 1 van 1
    • When all the screws are removed, pry up on the edges of the circuit board. You may need your plastic opening tool to access the edges.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Tanner
919 Reputatie
5 handleidingen geschreven
Één opmerking
Outstanding and that's from someone who has been turning screws on computers from the 8086 chip to and IBM 4381 then wrote a few books on the subject. This is the best tutorial I've ever came across, now do the G752. It's my next project after I find a motherboard.
Bill - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 28
Altijd: 1,692
