Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
With the computer upside down, lift up on the rubber cap on the back plate to access the captive Phillips #2 screw.
Retract the Phillips #2 screw until the cover is loose.
Pry around the edges of the plate using a plastic opening tool until the plate is removed.
Pull back on the tab on the hard drive shield until it is clear of the screw slots. Next pull the shield out.
With the hard drive exposed, pull the hard drive away from the connection point and then remove the hard drive.
