Ga door naar hoofdinhoud
Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement
Wat je nodig hebt
  1. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: stap 1, afbeelding 1 van 3 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: stap 1, afbeelding 2 van 3 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: stap 1, afbeelding 3 van 3
    • With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
    • You can now fully remove the battery from the device.
  2. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Track Pad Buttons: stap 2, afbeelding 1 van 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Track Pad Buttons: stap 2, afbeelding 2 van 2
    • Remove the large flathead screw holding the back cover in place.
    • Pull the cover off by prying it open starting from the top center and moving outwards.
  3. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: stap 3, afbeelding 1 van 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: stap 3, afbeelding 2 van 2
    • Remove the eight short screws holding in the two metal covers near the bottom.
    • Remove the two metal covers.
  4. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: stap 4, afbeelding 1 van 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: stap 4, afbeelding 2 van 2
    • Remove the battery to access the screws under it.
    • Remove these 16 screws with a regular Phillips head screw-driver.
    • These Phillips head screws will require a longer bit or an extension.
  5. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: stap 5, afbeelding 1 van 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: stap 5, afbeelding 2 van 2
    • Flip the device back over.
    • Pull off the plastic cover behind the screen.
    • Remove the four Phillips head screws holding the screen in place.
  6. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: stap 6, afbeelding 1 van 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: stap 6, afbeelding 2 van 2
    • With the screen removed, pry the piece that has the keyboard and the track pad on it.
  7. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: stap 7, afbeelding 1 van 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: stap 7, afbeelding 2 van 2
    • Remove the two Phillips head screws holding the buttons in place.
Conclusie
Josh Reyes
183 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 31
Altijd: 413
