Ga door naar hoofdinhoud
Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement
Wat je nodig hebt
  1. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement, Disc/Optical Drive: stap 1, afbeelding 1 van 2 Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement, Disc/Optical Drive: stap 1, afbeelding 2 van 2
    • Place the device upside-down. Unscrew the screw at the top of the cover and remove the cover by using a plastic opening tool.
  2. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove the screw that is located on the right edge of the removed cover. The screw is in a small opening.
  3. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: stap 3, afbeelding 1 van 2 Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: stap 3, afbeelding 2 van 2
    • Inside the opening that the screw was in, use a nylon spudger or any thin tool to push against the inside edge of the disc/optical drive.
    • With the disc/optical drive slightly popped out of the socket, pull the rest of it out by hand.
Conclusie
Jackson Reynolds
346 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 258
