Ga door naar hoofdinhoud
Asus ROG G74SX-DH73-3D Battery Replacement
Wat je nodig hebt
  1. Asus ROG G74SX-DH73-3D Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Asus ROG G74SX-DH73-3D Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Asus ROG G74SX-DH73-3D Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
    • You can now fully remove the battery from the device.
Conclusie
Jackson Reynolds
352 Reputatie
3 handleidingen geschreven
2 opmerkingen
The note bullet should just be a bullet. Check grammar on the Red bullet.
Joseph McCoy - Antwoord
“With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.” The sentence is too wordy you can remove “Where you can see the battery pop slightly up”.
Nicholas Ivey - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 25
Altijd: 396
