Ga door naar hoofdinhoud
Asus ROG G56JK Fan Replacement
Wat je nodig hebt
  1. Asus ROG G56JK Fan Replacement, Battery: stap 1, afbeelding 1 van 2 Asus ROG G56JK Fan Replacement, Battery: stap 1, afbeelding 2 van 2
    • Push the slider to the opposite side, while pulling out the battery.
    • Remove the battery from the device.
  2. Asus ROG G56JK Fan Replacement, Hard Drive: stap 2, afbeelding 1 van 1
    • Remove the 4 mm screw on the cover using a Phillips #0 screwdriver.
    • Remove the cover for the hard drive by pushing down and sliding it towards yourself.
  3. Asus ROG G56JK Fan Replacement: stap 3, afbeelding 1 van 1
    • Slide the hard drive to left and remove it from the device.
  4. Asus ROG G56JK Fan Replacement, Back Panel: stap 4, afbeelding 1 van 1
    • Unscrew the four 4mm screws using a Phillips #0 screwdriver.
  5. Asus ROG G56JK Fan Replacement: stap 5, afbeelding 1 van 1
    • Flip the computer right side up and start to lift the keyboard. The keyboard/back panel should come off.
    • Do not force the keyboard/back panel off. This could damage internal components and bend the keyboard.
  6. Asus ROG G56JK Fan Replacement, Fan: stap 6, afbeelding 1 van 2 Asus ROG G56JK Fan Replacement, Fan: stap 6, afbeelding 2 van 2
    • Unplug the red and yellow wires from the port in the motherboard.
    • Lightly pull on the red and yellow wires to release.
  7. Asus ROG G56JK Fan Replacement: stap 7, afbeelding 1 van 1
    • Remove the 5mm screw.
    • Remove the 4mm screw.
  8. Asus ROG G56JK Fan Replacement: stap 8, afbeelding 1 van 1
    • The fan is glued to the black box that it is inside of. When pulling the fan out, you may experience a small amount of tearing of the black box.
    • Gently pull the fan out of the black box.
Conclusie
Jonathan McNary
269 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 1,765
