Ga door naar hoofdinhoud
Asus ROG G56JK CD Drive Replacement
Wat je nodig hebt
  1. Asus ROG G56JK CD Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Asus ROG G56JK CD Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Push the slider to the opposite side, while pulling out the battery.
    • Remove the battery from the device.
  2. Asus ROG G56JK CD Drive Replacement, Hard Drive: stap 2, afbeelding 1 van 1
    • Remove the 4 mm screw on the cover using a Phillips #0 screwdriver.
    • Remove the cover for the hard drive by pushing down and sliding it towards yourself.
  3. Asus ROG G56JK CD Drive Replacement: stap 3, afbeelding 1 van 1
    • Slide the hard drive to left and remove it from the device.
  4. Asus ROG G56JK CD Drive Replacement, Back Panel: stap 4, afbeelding 1 van 1
    • Unscrew the four 4mm screws using a Phillips #0 screwdriver.
  5. Asus ROG G56JK CD Drive Replacement: stap 5, afbeelding 1 van 1
    • Flip the computer right side up and start to lift the keyboard. The keyboard/back panel should come off.
    • Do not force the keyboard/back panel off. This could damage internal components and bend the keyboard.
  6. Asus ROG G56JK CD Drive Replacement, CD Drive: stap 6, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, unscrew the four 4mm screws.
  7. Asus ROG G56JK CD Drive Replacement: stap 7, afbeelding 1 van 1
    • Gently pull the CD drive out of the side of the laptop and remove it from the device.
Conclusie
Brandon Wells
253 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 12
Altijd: 804
