Inleiding
This guide is for the replacement of a broken or faulty CD drive.
Wat je nodig hebt
Flip the laptop over so that the back panel is facing up.
Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
Remove the three 5.7 mm screws from the CD drive mounting points. Use a Phillips #1 screwdriver to remove the screws.
Bijna klaar!
Conclusie
