Inleiding
This guide is for the replacement of a broken or ageing battery.
Wat je nodig hebt
Flip the laptop over so that the back panel is facing up.
Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
Remove the three 5.7 mm screws from the CD drive mounting points. Use a Phillips #1 screwdriver to remove the screws.
Locate the hard drive in the lower right hand corner in the computer. This device did not have a hard drive so a piece of cardboard was used as a substitute.
Remove the two 5.7 mm screws from the base. Use a Phillips #1 screwdriver to remove the screws. Lift up to remove the hard drive.
Remove all fourteen 4.3 mm screws from the motherboard. Use a Phillips #1 screwdriver to remove the screws.
Unplug the three connections from the top of the motherboard.
Lift up at an angle to remove the motherboard from the computer. Take caution when lifting the areas where the USB ports are located. They are in small slots that exit the computer's main body. They will need to be slid through these slots to remove the motherboard.
Remove the three 4.3 mm screws holding the battery pack with a Phillips #1 screwdriver.
