Ga door naar hoofdinhoud
Asus Q552UB-BHI7T12 MotherBoard Replacement
Wat je nodig hebt
  1. Asus Q552UB-BHI7T12 MotherBoard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove all ten screws on the back of the laptop to remove the cover.
    • Remove the cover.
  2. Asus Q552UB-BHI7T12 MotherBoard Replacement: stap 2, afbeelding 1 van 2 Asus Q552UB-BHI7T12 MotherBoard Replacement: stap 2, afbeelding 2 van 2
    • Disconnect the wires at the top of the battery by lifting on the tabs protruding out of the plastic frame.
  3. Asus Q552UB-BHI7T12 MotherBoard Replacement: stap 3, afbeelding 1 van 1
    • Remove the four screws holding the battery in place, two on top and one on each side.
  4. Asus Q552UB-BHI7T12 MotherBoard Replacement: stap 4, afbeelding 1 van 1
    • Gently lift out the battery by the side closest to the motherboard first.
    • Be careful of any extra wires that may have attached itself to the battery.
  5. Asus Q552UB-BHI7T12 MotherBoard Replacement, MotherBoard: stap 5, afbeelding 1 van 1
    • Next you will be removing the cpu fan. Begin by removing the nine screws holding it in place.
  6. Asus Q552UB-BHI7T12 MotherBoard Replacement: stap 6, afbeelding 1 van 2 Asus Q552UB-BHI7T12 MotherBoard Replacement: stap 6, afbeelding 2 van 2
    • Then unplug the cable connecting into the motherboard.
    • Right next to the wire that was just unplugged, pull up and release the final clip attaching the fan to the motherboard.
    • Finally lift up and place aside.
  7. Asus Q552UB-BHI7T12 MotherBoard Replacement: stap 7, afbeelding 1 van 3 Asus Q552UB-BHI7T12 MotherBoard Replacement: stap 7, afbeelding 2 van 3 Asus Q552UB-BHI7T12 MotherBoard Replacement: stap 7, afbeelding 3 van 3
    • Next remove the screws at the top and bottom of the motherboard.
  8. Asus Q552UB-BHI7T12 MotherBoard Replacement: stap 8, afbeelding 1 van 2 Asus Q552UB-BHI7T12 MotherBoard Replacement: stap 8, afbeelding 2 van 2
    • Underneath the battery are 3 cables plugging into the motherboard, 1 wide one and two small ones. Lift the white tabs above them up, and then slide them out.
  9. Asus Q552UB-BHI7T12 MotherBoard Replacement: stap 9, afbeelding 1 van 1
    • Next you will need to remove the disk drive. You can follow our guide here.
  10. Asus Q552UB-BHI7T12 MotherBoard Replacement: stap 10, afbeelding 1 van 1
    • Move to the top of the motherboard and unplug the two cables that are connected.
  11. Asus Q552UB-BHI7T12 MotherBoard Replacement: stap 11, afbeelding 1 van 1
    • Move to the bottom of the motherboard and unplug the single cable near the battery.
  12. Asus Q552UB-BHI7T12 MotherBoard Replacement: stap 12, afbeelding 1 van 1
    • Now slide the motherboard back toward where the disk drive was, lift up and turn over. You will see a cable connected to the bottom of the board. Pull back on the dark plastic frame and then remove the cable.
    • Set the old motherboard aside and follow the steps in reverse to install the new one.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 18
Altijd: 1,443
