Ga door naar hoofdinhoud
Asus Q552UB-BHI7T12 Battery Replacement
Wat je nodig hebt
  1. Asus Q552UB-BHI7T12 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove all ten screws on the back of the laptop to remove the cover.
    • Remove the cover.
  2. Asus Q552UB-BHI7T12 Battery Replacement: stap 2, afbeelding 1 van 2 Asus Q552UB-BHI7T12 Battery Replacement: stap 2, afbeelding 2 van 2
    • Disconnect the wires at the top of the battery by lifting on the tabs protruding out of the plastic frame.
  3. Asus Q552UB-BHI7T12 Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the four screws holding the battery in place, two on top and one on each side.
  4. Asus Q552UB-BHI7T12 Battery Replacement: stap 4, afbeelding 1 van 1
    • Gently lift out the battery by the side closest to the motherboard first.
    • Be careful of any extra wires that may have attached itself to the battery.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Greetings I have tried to pull the battery out but i have issues making it go out of the place where it clicks, could you make a detailed video on how to safely remove that part without breaking the wires or the soldering on the board???
jorgealanhurtado95 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 3,323
