Inleiding
Hard drives (HDs) and solid-state drives (SSDs) can run out of space, run slow, or break. This guide will show you how to remove your current hard drive in an Asus Q551LN-BBI7T09 laptop so you can replace it with a new one.
Wat je nodig hebt
Use a T5 (Torx 5) screwdriver to remove the ten 3.0 mm Torx screws from the base plate of the laptop.
Één andere persoon heeft deze handleiding voltooid.
